KYB AGX help needed!!!!
Old Apr 10, 2005 | 09:36 PM
SamuraiBill's Avatar
SamuraiBill
Default KYB AGX help needed!!!!
I just ordered me a set but they did not fit into the dampener arm. I thought they were direct replacement. I checked to see if I was sent the parts but they are the correct ones. Should I have to modify anything? I drive a 92-95 civic si.
HELP PLEASE
thanks in advance,
Austin
Old Apr 10, 2005 | 10:01 PM
Nelson's Avatar
Nelson
Administrator
DOUBLE Check to make sure the part numbers are correct, otherwise, they should fit or you're doing something wrong.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Apr 11, 2005 | 06:32 AM
SamuraiBill
The part numbers are correct but bottom in of the shock is too wide and will not fit into the dampener arm.
austin
