Can anybody do this...???
Can anybody change the front parking light/turn signals into just turn signals since they are dual filament??? Or will 1156 single filament bulbs fit into the 1157 dual fil. bulb sockets and fit??? anybody got any ideas or know what to do???
thanks
thanks
Originally Posted by CPL
You can cover up the contact that provdes power to the parking light filament with tape or something so current wont pass through it.
you can cut the constant wire.
the problem with cutting the constant wire is that the blinkers blink with both filiments hot, so cutting the parking light out will make you blinkers dimmer.
its like in the brake lights, when they're normally on, they have the one filiment burning, but the second you tap the brakes, the second filiment comes on. Same thing as above if you were to change that.
one thing you can do to not change the brightness and still get rid of the parking light is to cut the constant wire, and then run a wire from the intermitant power (that gets power when you throw your blinker) to the other filiment that was on constant. That way, both filiments light up correctly :thumbup:
Originally Posted by CivicRacr
what actaully happened with mine is the parking filiment on both of my parking light bulbs actually blew out but the turn signal still worked
...forgot to mention my constant goes to my courtesy lamps.
h:
yeah, 5th gens have the extra corner bulb, don't they?
