01+ Civic "Maintenance Required" light
How do you reset this thing? All the older Civics have that spot in the gauge cluster where you just push your key into. My 03 does not have this and I want to turn that light off. It's getting annoying, and I just did a tune up.
did you check and see what code it was? If everything checks out and there is nothing wrong with the car, resetting the ECU will make it go away. Just unhook the battery and hit the brakes, hook the battery back up. If it still lights up, then theres something wrong and you need to check the code.
h:
