Ok, almost ready to yank engine out, but what about this?
Ok, I couldn't get the axles off with hand tools. So I'll do that first thing tomorrow after a quick stop to my friend Chris. So basically I pulled everything apart thats needed to be pulled apart. Then I got to this part, I don't know what to do.
http://www.armedandharmless.com/stuff/DSC00318.JPG
http://www.armedandharmless.com/stuff/DSC00319.JPG
http://www.armedandharmless.com/stuff/DSC00320.JPG
Basically the right fan and power steering section.
Uh, yea I guess? The swap guide doesn't say anything about it really. But yea that's what I'm asking, how to and do I need to? All that's left is the axles and halfshaft then it's comming out.
Your dseries motor doesn't have a 1/2 shaft.
PS: just remove the pump and push the lines aside. You'll probably have to drain the system, but that will happen when you take the lines off of the pump
A/C: you can just unbolt the compressor from the engine and use some wire or something to hang it. You don't even have to remove the lines or purge the system at all. That's What I did the first time I swapped.
dseries has not 1/2 shaft, bseries does. You will have to use it on your swap, you will see once you get in there.
A/C is 4 12mm bolts that hold it to the A/C mount on the engine. Just remove the belt and then remove the compressor. Simple enough.
