Changing Head Hasket
Changing Head Gasket
I'm getting ready to change my head gasket hopefully to solve my car getting hot problem
Anyways
I was wondering if anyone has a write up for the process or have any tips or tricks on changing head gasket?
What all needs to be taken off?
Tools needed?
Tricks and Tips?
Thing to look out for?
Thanks
Anyways
Tools needed?
Tricks and Tips?
Thanks
the head gasket is what sits between the header and the block. use a 10mm socket to take off the bolts. slide the header off, take the old gasket off, and slide the new one on. make sure that the bolts are put back on nice and tight so no exhaust is leaking. also, not too tight to where you strip it (a friend did that to his on accident) If you try to torque it too much, you can easily break the bolt right off the block and you can say bye bye to that...good luck and if you have any problems, were here for you at HAN!
Originally Posted by b18c1_hatch
I thougth that the Head Gasket went between the Block and Head. And the Exhaust gasket went between the the header and head.
The Exhaust gasket being exhast manifold gasket?
I wish it was a 20 min job
Still here... sorta...
Originally Posted by buzlink
Thats what I thought.
timing belt
tensioner
exhaust mani gasket
intake mani gasket
and an assortment of other gaskets/seals
You also have to drain your coolant to do the job.
Big 'oops' going on in this thread. h:
4500rpm hesitation
Originally Posted by Omniscient
Oh, I thought he meant just changing out the gasket sealing the header.
Even then I don't remember those bolts being 10mm's..
