boggs on acceleration
Old Mar 29, 2005 | 07:54 AM
kingbuzo's Avatar
kingbuzo
Default boggs on acceleration
1990 honda civic cx . dual point injection ,automatic
one day it just died on me ....replaced all the above and got it running..
symptoms:when cold ,idle idles fine and revs fine...once it warms up it misses a bit and when you stomp on the gas it boggs down... i am able to drive it as long as i keep the revs up ....it will idle at a stop sign but as soon as there is any load it wants to stall until i get the revs up and slam it in gear ( which isnt goood i know but it was the only way i could get home)
checked ecu and got code 16 *injectors *
i replaced cap rotor plugs and wires ,pcv valve,air filter,fuel filter, re soldered fuel relay, checked for vacume leaks and timing is good.... the only thing i havent checked is the fuel pressure because i dont have a guage to check with.....
*reset ecu by disconnecting battery*
ohmed out the injectors and they seem fine ...voltage to the injectors is good...it has 2 injectors main and auxillary...
while its running i unplug the top inj. and nothing happens (plug it back in )when i unplug the bottom one ...it stalls....
i guess both work on start up..... gas seems to be getting into the tb from the top inj.
please any suggestions thanks
Old Mar 29, 2005 | 01:11 PM
94civicEX's Avatar
94civicEX
I got worms.
Your injectors sound clogged, pull them out and clean them.
99 Integra GSR
06 TSX
duck squad member #00003
Old Mar 29, 2005 | 05:08 PM
kingbuzo's Avatar
kingbuzo
i tried to pull them out but were very hard to get out...*removed the 2- screw holding plate and tried to pull out by hand...but felt like they wouldnt come without some forse......im just not to sure how aggressive i can be with them.
Old Mar 29, 2005 | 05:13 PM
vtecnoobnc's Avatar
vtecnoobnc
Banned
yeah....if you replaced all that crap and it did nothing,you should obviously take it somewhere.
Old Mar 29, 2005 | 05:52 PM
kingbuzo's Avatar
kingbuzo
thanks , i know, but thats what i am trying to avoid....thats why i am here ...lol
