Headlight Help
Old Mar 25, 2005 | 10:59 AM
Brandons96civic's Avatar
Brandons96civic
Default Headlight Help
I have a 96 civic and I have had projector headlights for about a year. Recently my passenger low beam has been acting weird. When I start my car and turn my headlights on, the passenger low beam will not come on until I give it a firm punch. Then it will cut off and on throughout the drive. I have tried tightning the bulb and replacing the bulb but this only helps for a short amount of time. I wouldnt think that my harness is fried scince I only use 55 watt h4 bulbs. I have been ducking and dodging the police for months now and had several warnings. Any suggestions?
Old Mar 25, 2005 | 11:03 AM
honura's Avatar
honura
Seni
maybe something is wrong with the actual thing that holds the bulb make sure your getting contact and maybe file down the connections.
Old Mar 25, 2005 | 10:34 PM
Brandons96civic
thanks. I didnt even think of cleaning the connections.
Old Mar 25, 2005 | 10:39 PM
Nelson's Avatar
Nelson
Administrator
I know exactly what is wrong.
The problem is, the projector headlights uses cheap materials internally. The bulb (H3) is held in place by a think wire/spring/retainer mechanism. The actual problem is the retainer that holds the bulb in place is very thin, and often warps due to the heat given off by the bulb.
I remedied this with two options:
1) Using a small ball of aluminum foil behind each prong on the retainer that holds the bulb in place.
or
2) Less ghetto, I used a metal waster behind the bulb to have it pushed closer/tighter to the retainer.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Mar 26, 2005 | 11:18 AM
Brandons96civic
Yeah the projectors I have seem kinda cheap. Thanks man. Do you know of any good projector headlights Or HIDs? I might buy some more in the future, but only top of the line shit.
