Split-Fire for Civics?
Old Mar 22, 2005 | 03:58 PM
300's Avatar
300
The Last Katana
Default Split-Fire for Civics?
its about time for new spark plugs for my 96 civic ex
i did have good result using split-fire in my carburetor cars
wonder if this triple-platinum (TP522D) will do any good?
has anyone ever tried this?
Old Mar 22, 2005 | 03:59 PM
Wharbone's Avatar
Wharbone
just get the oem NGK plugs. They work really well, and are cheap.
Old Mar 22, 2005 | 05:21 PM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
Ive tried several different plugs and ngk and champion (yes the cheap ones that every store has) work the best
Old Mar 22, 2005 | 05:47 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Yup, NGK.
Old Mar 22, 2005 | 05:56 PM
The G2 Racer's Avatar
The G2 Racer
Want Boost!
Stock NGK.
Whatever you do stay away from Bosch plugs, I had some bad problems in my old hatch with them.
Old Mar 22, 2005 | 08:23 PM
meunit910's Avatar
meunit910
Originally Posted by The G2 Racer
Stock NGK.
I have bosch Platinum 4 spark plugs right now...what problems did you have with them? To be honest with you i really dont like them that much either.
Old Mar 22, 2005 | 10:05 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I had a really rough idle and random misfires with both my bosch and denso plugs. Then I switched back to NGK's and it smoothed everything out.
Old Mar 23, 2005 | 03:39 AM
The G2 Racer
Want Boost!
Bad idle and the oil seals in my valve cover went thus causing the plug leads to pop of the plugs.
Nothing better then running on 3cyl.
Old Mar 23, 2005 | 05:24 AM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
NGK work very well use those ones
Old Mar 23, 2005 | 07:51 AM
twinring's Avatar
twinring
denso or ngk iridiums
