My Emergency Light Wont Work!
Old Mar 22, 2005 | 06:25 AM
oudi's Avatar
oudi
Banned
Default My Emergency Light Wont Work!
WHAT SHOULD I DO IS THERE A FUSE FOR THEM?IT was in an accident you think its electrical?any ideas?
Old Mar 22, 2005 | 01:39 PM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
ok first... you need to include more with your question... what have you tried? what year civic? what model? does anything else not work? Do normal blinkers work?
I'm shooting in the dark here, but there is a 10A fuse for the hazard lights in the under hood fuse box, I'd start there.
Old Mar 23, 2005 | 06:50 PM
oudi's Avatar
oudi
Banned
normal blinkers work,checked fuses etc.it was in a accident and is a 1998 civic dx 2 dr.
Old Mar 23, 2005 | 07:44 PM
fightinchunk's Avatar
fightinchunk
there should be fuses for these. But im not entirely sure since your blinkers work. Check the panel that covers the fuses, it should say there on the label.
Old Mar 24, 2005 | 08:24 AM
Relic1's Avatar
Relic1
since your normal blinkers work it is probibly this...
Originally Posted by Relic1
there is a 10A fuse for the hazard lights in the under hood fuse box.
or a problem in the wire that carries that power to the hazard switch.
Old Mar 24, 2005 | 09:43 PM
Bricks2k4civic's Avatar
Bricks2k4civic
take the dash apart (or where ever your hazard light is, im not sure off hand) and check to make sure the harness is tight. I've had a problem with that coming undone. The fuse for the blinkers and emergency light is the same fuse, so its not the fuse.
Old Mar 24, 2005 | 09:47 PM
DC2Slow's Avatar
DC2Slow
HUNG LO IS MY FRIEND
i suggest checking the fuse under your dash as well as the one under the hood. good luck bro
Old Mar 25, 2005 | 08:11 AM
Relic1's Avatar
Relic1
I'm afraid you are incorrect.
There has to be a seperate fuse (I'm 100% positive there is for a '98 DX coupe).
Why is this?... because blinkers have power only in Run, hazards have power at all times. So it has to be seperate fuse. Also the Honda service manual I'm looking at says there is a seperate fuse.
