custom trunk light?
Old Mar 22, 2005 | 03:51 AM
oldskoolcivic's Avatar
oldskoolcivic
Default custom trunk light?
i got a 94 dx coupe and theres no trunk light when i open the trunk. sucks ass when its all dark at night trying to find stuff in there. i know my guage cluster has the open trunk light, when my trunk is opened the light goes on, so i guess theres a + wire for current to go to the cluster, so maybe if i find that + wire and i just ground that with a light bulb, it might work?
Old Mar 22, 2005 | 06:24 AM
szuberi's Avatar
szuberi
I guess you have this one figured out. Is the wire issue only...check if you have the bulb or not?
Old Mar 22, 2005 | 06:37 AM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
The one in the cluster is a ground wire (-). I used it in my alarm for the trunk pin sensor (I want to say its blue...but I cant remember)
Just run a wire from that and a positive constant power and you'll be set
Old Mar 22, 2005 | 07:14 AM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
Yes. Set. Personally though I found that my trunk light wasn't enough since a lot of times I would end up blocking the light with stuff as I put stuff in or took it out. It was mostly about the position of the bulb IMO. I always thought it should have been mounted closer to the seat.
My point: while your at it check out positions to put it where it will be most useful.
Old Mar 22, 2005 | 08:20 AM
dnt94civic's Avatar
dnt94civic
I got 2 trunk lights on my DX. Look for a black wire that goes to the trunk mechanism.
Old Mar 22, 2005 | 01:32 PM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
the dark green wire that runs to the trunk mech is ground for your light. Run a wire to constant power through a fuse and you're done.
Old Mar 22, 2005 | 02:45 PM
speed_69's Avatar
speed_69
now that i think of it...is there any way to get a hood light?
Old Mar 22, 2005 | 03:00 PM
Relic1's Avatar
Relic1
install a hood pin for an alarm, wire like I mentioned above.
Old Mar 23, 2005 | 09:54 PM
oldskoolcivic
wheres that green wire located? i looked over the trunk and cant find it. like where is its path that goes to the cluster?
Old Mar 24, 2005 | 04:58 AM
PDiggityDogg
Yeah, for a hood light just buy one of my $2 alarm pin switches (http://www.honda-tech.com/zerothread?id=1177019 ).
Connect the light's ground to the pin switch and another to constant power....battery.
