How do you take out window crank???
Alright, im on dail up, so i dont feel like looking up stuff at the moment. If some one can explain how to take out the window crank or give me a link to a post about it. Greatly appreciated. Seriously, im just thinking you just pop that sucker out but i dont want to ruin anything.
What car and read the sticky at the top of this section... :uhhok:
civic coupe LX 2003
I'm not up to date on the 2001+ civics but my 93 has a clip behind the crank, in between the door panel and the back of the crank. I just bent a paperclip into a hook and pulled the clip out.
they make a tool that all bodyshop guys have that looks like a huge fork with 2 teeth and u put it under the tab and pry is GENTLY. a screw driver or tiny crobar would work
I'm not up to date on the 2001+ civics but my 93 has a clip behind the crank, in between the door panel and the back of the crank. I just bent a paperclip into a hook and pulled the clip out. they make a tool that all bodyshop guys have that looks like a huge fork with 2 teeth and u put it under the tab and pry is GENTLY. a screw driver or tiny crobar would work Hey, thanks everyone for taking the time to help me. I know im always rushing things and always try to look for the fast way out. |
screw all that, get a peice of cloth and stick it in behind the crank between the door panel and the crank, then move the cloth back and fourth like you were shining a pair of italian shoes, the clip will come right off... this is an old wives trick and a shade tree mechanics secret.
Actually, i think it's just better to spend a couple buxs for a tool. It's only like 7 buxs and makes it a whole lot easier.
Btw, westcoaststyle...uhh...lolz...i JUST read your sticky post... I knew i should have read it when i saw it and also knew that there had to be a specific section for my situation. But like i said, im constantly rushing because i rarely ever have time. Figured i'll get a quick answer and no one would mind the post. Though next time for sure i'll post in the right spot. I know it's gotta annoy someone when they see a post out of place. |
