D16Y7 Intake Manifold Swap
The intake manifold on the d16y7 is so whack. I cant install a front strut bar on my car because the intake pipe gets in the way. I was wondering if I could just swap on another intake manifold, im thinking off of a d16y8 vtec. Would it work? Is it a direct bolt on or will I have to do some modifications?
Got V-TEC??
its really easy... just remove some bolts and hoses... get a new gasket.. put the new manifold, plug everything back and connect some hoses and ur ready to go.....
5-finger discount :rick:
Got V-TEC??
Originally Posted by '93TurboD
Not quite that simple. I have a D16Y7 with D15 manifolds and I ended up with some small problems. The intake manifold gets it's coolant from the water pump tube @ the back of the block. You'll have to get the matching tube and coolant hoses from the car that the intake came from. Beyond that it's pretty easy.
