Another ECU question
Old Mar 12, 2005 | 07:32 AM
alllooksnnogo's Avatar
alllooksnnogo
Just another import lover
Default Another ECU question
Hey bro's. I'm planning on programming an ECU for use with my B16B. I'm selling the current PCT ecu and either planning on using a P28 and programming it or a hondata setup. What would you recommend?
Old Mar 12, 2005 | 08:25 AM
JaVa_230's Avatar
JaVa_230
u should try uberdata. the software is free and its easy to use and works well. if you can solder you can do the chipping yourself or just buy one pre-chipped. www.ecimulti.org/uberdata
Old Mar 12, 2005 | 08:26 AM
JaVa_230's Avatar
JaVa_230
Old Mar 12, 2005 | 09:56 AM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
personally I'd go with the P30 with Uberdata or Chrome.
the only difference between the P28 and P30 is the knock sensor in the P30.
Which is you can easily disable on the P30 if you wish, but can't enable on the P28 if you want it. (actually you can install one, but it's not easy)
Old Mar 12, 2005 | 10:43 AM
alllooksnnogo
Cool idea guys Good point on the knock sensor as well with the P30
Old Mar 12, 2005 | 11:23 AM
Snoopy's Avatar
Snoopy
been there done that
if you're the diy type person, get uberdata or crome like mentioned. if you dont think you're capable of doing the tuning yourself, get hondata. if you do plan to do your own tuning, look into picking up a wideband o2 as well.
Old Mar 12, 2005 | 12:11 PM
Snoopy's Avatar
Snoopy
what mods do you have IN the engine or what plans do you have that require you to get an ems?
Old Mar 13, 2005 | 05:22 AM
alllooksnnogo
I only have the basics done bro. Intake & wires. I want to relieve myself of the painful governor and increase my numbers a little. It would be nice to have some solid control of the fuel/air managment in the future but that would be off in the far distance
