Metallic sound during engine rev
Old Aug 25, 2002 | 02:41 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
Default Metallic sound during engine rev
Well, first off, I know its not the best thing to rev your engine in nuetral, but regardless....
when I rev my engine up, around 5-6k RPMs, I hear this metallic scrapping sound :dunno:
its not so bad on the way up, but comming back down the Tach, its real obvious. Any clue what it is.
and yeah, its the D16y7 (I beleive? '96 lx w/ vtec)
Old Aug 25, 2002 | 03:07 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
Exhaust heat sheilds... Rip em off, you're fine!
Old Aug 25, 2002 | 03:09 PM
19.3secS2K's Avatar
19.3secS2K
any How-To's?
you are serious, right? :fawk:
Old Aug 25, 2002 | 03:14 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
first thing, pop your hood and flick your heat sheild on your exhaust manifold. If it buzzes, that's probably it. Tighten the bolts. If not, jack up the car and start hitting the exhaust every so often with a screw driver until you hear it buzz or rattle. Then either unbolt it, tighten it, or rip the sucker out. It doesn't add any noticeable amount of heat to the cabin... Anyone that tells you it does, will also tell you that a cat back system is enough to make your floor boards melt.
Old Aug 25, 2002 | 05:43 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Also, check your header hanger. That thing can get loose and it rattles with a weird sound.
Old Aug 25, 2002 | 07:49 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
word, two 14mm nuts. or are they 12's??? Too late tonight to remember...
Old Aug 26, 2002 | 12:36 PM
westcoaststyle
I think 12s...
Old Aug 26, 2002 | 09:29 PM
19.3secS2K's Avatar
19.3secS2K
I'll take a look on my next day off
Old Aug 27, 2002 | 05:57 AM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
heat shields for sure. mine do it at about 2500. i thought it was the resonator heat shield, but i think in actuality its the header heat shield. im boughts to kill that one too
Old Aug 27, 2002 | 04:28 PM
westcoaststyle
I think 12s...
Nope, it's 14s I checked.
