will a obd-0 intake manifold and tb work on a obd-1 ecu??
yes, but its gonna suck ass routing all the vac. lines to the dashpots, and also they throttle body is setup different the way the Fast idle valve works....if I were you I would stick to same obd :thumbup:
what motor...I know that the obd-0 b16a manifolds have a different way the tb attaches because of some of the ports on the intake manifold that are used for the fast idle valve and some other non-sense...I would stay away from the obd-0 if you have obd-1 nothing good will come of it.
if its a first gen goin into a 92-95 I would highly highly rec. getting the p-30 obd1 intake manifold and matching or bigger obd1 TB, dizzy, injectors. it just makes life easier, and it is a better manifold and a bigger throttle body
edit: I think I got my IM for like 40 bucks and my TB for like 60ish....I got the JDM sir-G throttle body.
