Need Help Identifying a Caliper, (4 pics)...
Old Mar 3, 2005 | 11:15 AM
MakDiesel's Avatar
MakDiesel
I
Default Need Help Identifying a Caliper, (4 pics)...
I've posted on other Honda forums w/ no luck. I need to know what year(s), model(s), and whether it is ABS or not on this caliper. Brakes are not my forte'.
And if those don't work:
Pic 1
Pic 2
Pic 3
Pic4
I called a Honda Dealer with part numbers but they were of no help. Apparently the numbers on the caliper are manufacturing numbers, not part numbers.
Thanks, Mak
Old Mar 3, 2005 | 11:34 AM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
What is the distance between the mounting brackets? It looks small...like less than 4"
Where the line connects looks pretty different from what I've seen. That and the fact that there is only 1 bolt connecting the bracket to the caliper itself.
They look like no ex/si, abs, or integra calipers that I have ever seen.
Where did you get these?
Old Mar 3, 2005 | 01:06 PM
Running925's Avatar
Running925
Your Powder Coater
idk.. but it looks like it could use cleaned & powder coated! :rick:
Old Mar 3, 2005 | 01:58 PM
MakDiesel's Avatar
MakDiesel
I
I got them off ebay (first mistake) and the guy who sold them said they came off of a '95 Civic. I asked about model (lx, dx, vx, ex, etc) and he said either lx or dx, but def. not ex (thus not abs). I just needed two front base 92-95 Civic calipers to finish my '85 CRX Si brake swap but nooooo...I got this bullshit. The other forums I've posted this on also don't recognize and/or are being a smartass about it. (it's a '97 Civic, white, w/ 107k miles and a dent in the trunk crap) Mak
PS. I won't clean or powder-coat them until I know what the hell they fit on.
Old Mar 3, 2005 | 02:17 PM
MakDiesel's Avatar
MakDiesel
I
Distance between the mounting brackets? You mean between the two bolts on the bracket? If so it's 5.25"
Old Mar 3, 2005 | 03:30 PM
PDiggityDogg
Alright, I dug out my old ex/si calipers to measure.
Its 5 1/16" on the inside of the mounting holes on the brackets.
The piston outter diameter is also 2"
They just look really strange to me.
If you want a set of ex/si brakes off a 97 I have a set for sale (rusty but still work - check my sig for the package deal)
Old Mar 3, 2005 | 03:53 PM
MakDiesel's Avatar
MakDiesel
I
my piston outer diameter is 2.5"
Old Mar 3, 2005 | 04:18 PM
PDiggityDogg
The diameter of the piston should make them abs/integra but the fact that the mounting bracket distance is larger I cant say what they are...
Where are you taking the mounting bracket's measurement at? Center of the holes or the outside?
Old Mar 3, 2005 | 05:10 PM
MakDiesel's Avatar
MakDiesel
I
center....and I remeasured it, it's more like 5 1/8"
Old Mar 4, 2005 | 07:02 AM
89civicSiR's Avatar
89civicSiR
thats right im a NOOB!
they look fairly close to my calipers on my 89civic hatch sir close but those ones u have look lighter than mine...here is what mine look like so i think you can eliminate 88-91 models
File Type: jpg
