what rpm to shift?
Old Feb 28, 2005 | 11:20 PM
300's Avatar
300
The Last Katana
Default what rpm to shift?
just got my 96 civic ex, couple weeks ago
i'm having hard time to engage the clutch smoothly
especially at 1st gear, or anytime i up-shift below 3k rpm
have to rev it above 3k rpm, and release the clutch much slower than any
other cars i've driven, in order to have a smooth engagement
wonder if thats normal for civics, or the clutch is worn?
according to owner's manual recommended shift speeds, approx 3.1k rpm
before upshift, isnt thats a little high? or civic's torque is really that low?
Old Feb 28, 2005 | 11:37 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The torque on Honda motors is pretty pathetic, so if you are having issues with engaging the clutch, shift a little higher until you find the spot that works for you. I cannot shift anywhere under 4k rpms. But I have a GSR, which revs much higher anyway. The recommended shift points in the owners manual make the car way too slow to even bear, so shift a little higher to get the acceleration you need/want and the clutch to engage a little smoother.
Old Mar 1, 2005 | 08:50 AM
89civicSiR's Avatar
89civicSiR
thats right im a NOOB!
i agree with shmoo. but the weird thing is when it snowed this winter and it was really icey i shifted from 1-2 at 2krpm and then 2-3 at 2krpm and so on to 4th and when i was doin that my car shifted fine and the clutch engaged just as smooth as it does at 4k rpm
Old Mar 1, 2005 | 08:57 AM
honda_pilot's Avatar
honda_pilot
DeeCeeFo'
I shift at 2k rpm most of the time. But then again I have full torque at slightly over idle. h:
Old Mar 1, 2005 | 10:18 AM
lkailburn's Avatar
lkailburn
college kid
i've shifted at the honda recommended points before and it was insanely smooth. wasn't blazing fast obviously but u could barely tell it was a 5spd lol.
on normal driving i shift around 3500
Old Mar 1, 2005 | 10:22 AM
Falkon's Avatar
Falkon
still alive
What's with you F1 daily drivers? In my del Sol Si, I shifted right at 3k rpm and never had a single issue, because I can actually drive a manual and would end up accelerating faster than cars with gobs more torque. This, of course is in a normal traffic situation. I didn't floor the car. The 96 has a MUCH shorter clutch engagement than the EG. You get used to it. I actually prefer the 96+ clutch.
Old Mar 1, 2005 | 10:54 AM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
Falkons got a point. Shifting gears at speed is a lot like with take off. You just have to find that sweet spot. Get the clutch right and the car rips forward. Do it the wrong way and you end up moving out like extra slow and that puts exess wear on the clutch.
Old Mar 1, 2005 | 11:07 AM
thomas's Avatar
thomas
pew pew pew
i shift at redline about 7200rpms......
Old Mar 1, 2005 | 05:43 PM
95civicex4dr's Avatar
95civicex4dr
JHMEH9
i reccommend to shift around 3k when the car is not warmed up yet, after that anything is fair game...
Old Mar 1, 2005 | 06:38 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
i always bounce it off the rev limiter when i upshift, i never had any problems yet :dunno: in all seriousness i would shift at 3k, good for speed and gas mileage.
