hit a little snag
turning u inside out
hit a little snag
alright, so i mounted the mani and the turbo last night to see how it would fit, and theres a lil ****ing bracket in the way. now should i take it off or grind it down, the tubo fits, but the downpipe will have no room. any suggestions. and losing the internal wastegate is not an option, so dont go there.
Relevance is irrelevant
Yeah I'd say grind it down. I'm really not sure why they used that much metal in the first place. I mean that's friggin steel. It could be half that size and still work.
(i think...)
(i think...)
the bolt to the top left will not be able to stay and ill have to grind that done abit and a lil more of the bracket. so will it be safe
the section you highlighted in red....cut it off...take the peice off, and the area selected just torch it...there is more than enough material holding the alternator on without said bolt.
edit: or just fab up your own bracket that doesnt conflict with your down pipe. I :dunno: if that is an option, if you have the tools/skills/etc but that is what I would prob do
