Rack and Pinion
junk yard...classifieds forum...honda motor company.
It's a lot easier and typically less expensive to replace the entire thing rather than rebuild one.
Or are you looking to change the ratio of yours?
You have a rack and pinion setup now, but it's power assisted. You can simply take out the power steering pump and lines, drain the rack and connect the inlet to the outlet hoses and run it that way.
AFAIK the manual rack is different inside than the power rack.
You may have to pick up a manual rack to install that kit, but I'm not sure. Give them a call, I'm sure they've been asked that before.
