intake question??
Old Feb 23, 2005 | 04:33 PM
JesterMasque's Avatar
JesterMasque
ETERNAL GRINNING ^
This scares me cause I wanna get a CAI but now I realize how it's not so simple of a thing to install and maintain...
Old Feb 23, 2005 | 05:10 PM
chimchim's Avatar
chimchim
WRX cuz Honda won't wagon
It is simple. The problem described above would be happening whether or not he has a stock intake on or a CAI. As long as you hook up the breather hose and the temperature sensor as per the installation instructions, you'll be fine.
Since it sounds like you're new to this, here's what I learned (quick explaination):
- the temperature sensor in the intake senses the intake air temperature and is used as one of the parameters by the ECU (car computer) to estimate the amount of O2 (oxygen) that's going into the combustion chamber so it know how much fuel it should mix with it
- the breather hose is needed because air pressure can build up in the crankcase area of the engine. The pressure comes from several things, the main thing because "blow by" of the combustion past the piston rings. This pressure needs somewhere to go so a breather hose is the vent. However, since this contains unburnt gas and oil, it is an environmental polluter so the hose is routed to the intake so the stuff can go back through the intake to be combusted.
Old Feb 23, 2005 | 11:49 PM
89civicSiR's Avatar
89civicSiR
thats right im a NOOB!
i suppose i should ask this in here instead of starting a new thread. do the intake filters with the recessed cone filter into the top limit the power compared to just the flat top cone filters?
Old Feb 23, 2005 | 11:58 PM
chimchim's Avatar
chimchim
Post a pic so we know what you're talking about.
Old Feb 24, 2005 | 07:49 AM
89civicSiR's Avatar
89civicSiR
ive heard that these filters can limit the power gain of intake compared to the one with just a plain old flat top filter....is this true
File Type: jpg
Old Feb 24, 2005 | 08:46 AM
Running925's Avatar
Running925
Your Powder Coater
very good explaination!
Old Feb 24, 2005 | 09:36 AM
chimchim's Avatar
chimchim
Where did you here this?
Old Feb 24, 2005 | 10:39 AM
89civicSiR's Avatar
89civicSiR
this guy up in iowa (not sure how much he really knows about cars) but he had a nice 1991 turbo supra til he hit a tree....bo they both end up giving you the same amount of power tho or is one of them better???
