Did I Blow My Motor??!!!
I DROVE THROUGH A POOL OF WATER ON A RAINY DAY...AND MY CAR IS SO LOW THAT THE COLD AIR INTAKE SUCKED UP SOME WATER. MY CAR CHOKED AND CUT OFF, NOW IT WONT EVEN CRANK NO MORE...WATZ DA PROBLEM, CAN SOME ONE PUT ME ON TO WATZ THA PROBLEM???
Your Powder Coater
Originally Posted by meberra
Yep i'd say u hydrolocked it. This i one of the Main reasons way i dont have a CAI. next time invest in a AEM bypass valve. :doh:
just a generic short ram with a K & N cone filter would do just fine
I'm made of meat!
I have a CAI, I drive in the rain, I run through puddles, I don't have a bypass valve, but I have my splash guards still in place. I have no problems. I don't go swimming in my civic, but something in me screams that a lot of CAI's are installed improperly or that there are other factors that contribute when this occurs.
BTW: My car is not lowered.
Pull your spark plugs out of the car and try to crank the engine until no more water sprays out. Make sure it comes out of all 4 holes or you may have broken a camshaft, pushrod, or valves. That would not be good as you will be replacing that motor in order to drive your car again.
I would go ahead and swap the engine, put a bypass valve on the new engine along with the cold air and put splash gaurds. In the winter time though take off your cold air and run a short ram.
