Turbo to Downpipe Gasket
Old Feb 17, 2005 | 10:21 AM
Running925's Avatar
Running925
Your Powder Coater
Here's a pic that i found on ebay that looks like the flange that i have...
need to find a gasket for this style flange
File Type: gif
Old Feb 17, 2005 | 10:48 AM
Jafro's Avatar
Jafro
I'm made of meat!
Huh? Your Downpipe connects to this? That's weird. Where is your o2 housing? (DSMers have a cast iron collector that bolts to the turbo, and it has an o2 sensor bung on it, so they call it an o2 housing). Usually a downpipe is round at the flange. and uses 2 to 4 bolts to hold it on.
I want a pic of the downpipe. :thinking:
Old Feb 17, 2005 | 10:52 AM
swaggs21's Avatar
swaggs21
My 02 bung is down by my cat, and most dp for civic connect down there also I am pretty sure, you just have to make extensions for it...
Old Feb 17, 2005 | 10:58 AM
Jafro's Avatar
Jafro
I'm made of meat!
Pretty much anyone that sells those turbos should have them. I'm going to assume it's a Turbonetics setup by the pic you posted. www.slowboyracing.com and www.agpturbo.com if www.roadraceengineering.com doesn't have them.
Old Feb 17, 2005 | 11:05 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
As is mine.
It would help to know exactly what turbo you have before ordering the gasket. Jafro has given you the resources to find it once you know what turbo you have.
Old Feb 17, 2005 | 11:25 AM
Running925's Avatar
Running925
Your Powder Coater
It's the Turbonetic's 5 bolt pattern on the turbo & i bought the flange on ebay & made the down pipe, my o2 sensor bung is welded on my down pipe before the cat near the firewall.
Old Feb 17, 2005 | 12:19 PM
Jafro's Avatar
Jafro
I'm made of meat!
They might have it. What turbo is it again?
I don't have a gasket between my turbo and DP. :thinking:
WCS nailed it.
Is this what you need? $15+shipping
It's at roadraceengineering in their DIY parts section. They also sell the turbo flange for people like you that make their own downpipes . You'll have to punch a hole in it if you're internally gated.
File Type: jpg
Old Feb 17, 2005 | 12:28 PM
Running925's Avatar
Running925
Your Powder Coater
WCS nailed it.
That is EXACTLY what i was looking for! Thanks guys!!
it's externaly gated so it will require no modification
Old Feb 17, 2005 | 01:25 PM
raiden571's Avatar
raiden571
turning u inside out
why not just make your own, NAPA has high temp gasket kits. they sell it in 3 sq/ft sheets and its cheep.
Old Feb 17, 2005 | 03:15 PM
Running925's Avatar
Running925
Your Powder Coater
gasket paper will not hold up in this situation..
