Civic Suspension problem!!!
Old Feb 9, 2005 | 09:13 PM
dawrenn's Avatar
dawrenn
Default Civic Suspension problem!!!
I just recently got new suspension installed on my 99 Civic. When I was driving today I heard a clanking sound come from the rear of the car. When I looked in the trunk I saw the bolt, the bushing, the washer, and the bolt collar off of the right strut and when I looked at the left strut I saw the the nut was about to come off. Why do you think that happend? Were the nuts not tight enough? Do you think anything got damaged? Could the strut have blown? I probably only drove about a mile or 2 to get home. Will it be easy to get it back together? Will I have to take the strut completly off of the car? I need to know something ASAP.
Old Feb 10, 2005 | 06:12 AM
teg92's Avatar
teg92
WHAT OK YEAH!
it probally wasnt on tight enough just try to put everything back together without taking the strut off, if you cant then you have to take it off and re-do it
Old Feb 10, 2005 | 07:02 AM
Ghosty's Avatar
Ghosty
Honda y0
yeah shouldnt be too hard, sounds like you just need to tighten them down, use a imapact wrench, if you have one, but either way it shouldnt be to bad.
Old Feb 10, 2005 | 07:13 AM
dawrenn's Avatar
dawrenn
So you don't think anything got damaged? I am just worried that something got bent.
Old Feb 10, 2005 | 07:21 AM
drklver's Avatar
drklver
you should be fine just make sure you have all the parts.
did you get this installed at a shop?
if so if anything is damaged they should replace it for free.
Old Feb 10, 2005 | 07:35 AM
teg92's Avatar
teg92
WHAT OK YEAH!
i dont think anything would get damanged
Old Feb 10, 2005 | 09:10 AM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
You don't use an impact wrench for the top nut. You use a torque wrench and torque it to spec.
Old Feb 10, 2005 | 09:15 AM
dawrenn's Avatar
dawrenn
I did get it done at a shop. I called the shop that installed my suspension they said they are going to send a mechanic down here and if they cant fix it on the spot they are going to have it towed to there shop :thumbup:
Old Feb 10, 2005 | 12:55 PM
swaggs21's Avatar
swaggs21
Loc-Tite is your friend.....
Old Feb 10, 2005 | 03:31 PM
LSturbo's Avatar
LSturbo
You shoI told dawrenn he should have called them.
