car wont start,timing problem?
Old Jan 27, 2005 | 05:32 AM
oreo kookie's Avatar
oreo kookie
Default car wont start,timing problem?
my car wont start,its getten gas,spark and compression,could i have jumped tyming??
Old Jan 27, 2005 | 05:34 AM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
Wow thats vague, I don't know, could you have?
Why dont you check it?
Old Jan 27, 2005 | 05:40 AM
KAUAI KANE's Avatar
KAUAI KANE
91' Toyota Supra
From: Iwakuni, Japan. And where ever the Marine Corps sends me
Have To Be More Descriptive Than That
sibiryk's Avatar
sibiryk
How do you know that it's getting gas?
Old Jan 27, 2005 | 05:42 AM
inHISgrip's Avatar
inHISgrip
If you have skipped time your car will not start.
Old Jan 27, 2005 | 05:51 AM
oreo kookie
i checked it,so its getten gas and spark ,but it jus turns over wont start up
Old Jan 27, 2005 | 06:00 AM
sibiryk's Avatar
sibiryk
Maybe timming belt is broken. I don't know if pistons will hit valves or not on your engine. I saw such a thing once. You can open oil cap and see if valve moves when you turn engine over.
Old Jan 27, 2005 | 06:02 AM
teg92's Avatar
teg92
WHAT OK YEAH!
my brothers teg was doing the same thing until we took the valve cover off and saw that the timing belt was in 2 pieces
Old Jan 27, 2005 | 06:43 AM
Jafro's Avatar
Jafro
I'm made of meat!
Does it crank real fast... or faster than usual? If you don't have any exhaust leaks, and you cover the exhaust and crank it... and it doesn't build up pressure, the timing belt is hosed. It's another less-technical way of checking the belt.
Old Feb 8, 2005 | 03:25 PM
davidn71's Avatar
davidn71
95 Civic w/ b16 swap
Anyone think to check the coil? My bro's integra did the same. Popped the distributor off, put in a new coil, and it was good as new......
