help! muffler problem?
Old Jan 26, 2005 | 05:32 AM
phil_boy's Avatar
phil_boy
Default help! muffler problem?
hi, i've recently installed a tanabe muffler onto my civic. after turning off the engine and opening the hood, the engine feels a lot hotter than usual. is this just normal? do i have to change something on my car to support my new muffler? btw, i've also had my filter change to hks prior to installing the muffler (but it works just fine until intalling the muffler). am i doing something wrong or forgetting to put something. i need your advises. thanks.. God bless.
Old Jan 26, 2005 | 06:26 AM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
Did you touch your engine to see exactly how much hotter it is?
Old Jan 26, 2005 | 06:46 AM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
:rofl:
Old Jan 26, 2005 | 06:49 AM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
seriously, just check your temp gauge. if its fine there, dont worry. Maybe you're riding harder b/c you like the sound? The ecu will re-learn itself, eventually....if you reset the ecu it will relearn quicker...
Old Jan 26, 2005 | 06:52 AM
phil_boy's Avatar
phil_boy
no, it just felt like really hotter (the air that comes out when you first opened the hood, remember that i opened the hood right after shuting off the engine). the hood (i've touched it) is also hotter than usual.
Old Jan 26, 2005 | 06:56 AM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
might just be relative, like i said. When i first put on my exhaust, i loved the response and the sound so i drove harder than usual. Might have raised the temp 10-20 degrees more, which isnt really much, but it would feel hotter. I'd just go my your temp gauge, maybe flush your coolant system out (if you haven't done recently) and enjoy.
Old Jan 26, 2005 | 06:57 AM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
also, do an oil change if needed....helps keep the engine cooler
Old Jan 26, 2005 | 06:58 AM
phil_boy's Avatar
phil_boy
my temp gauge is fine and i don't think i was riding harder. i was stepping the gas the usual way.
Old Jan 26, 2005 | 07:02 AM
phil_boy's Avatar
phil_boy
hmm.. might as well just keep an eye to the temp gauge. anyway thanks to all your advises.
Old Jan 26, 2005 | 07:03 AM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
no prob.
