H22a or B16a
Old Jan 25, 2005 | 09:41 AM
crazydrifter204's Avatar
crazydrifter204
95DX
Default H22a or B16a
Which engine do you think is better in a 95 civic?
Old Jan 25, 2005 | 09:42 AM
Running925's Avatar
Running925
Your Powder Coater
Neither!
i'd go with a B18b
Old Jan 25, 2005 | 09:49 AM
ED9man's Avatar
ED9man
driver
If you have the cash go with a B18C1.
Old Jan 25, 2005 | 10:34 AM
thomas's Avatar
thomas
pew pew pew
does the h22a have oil squirters like the b18c5...
Old Jan 25, 2005 | 05:39 PM
AcuraIntegraLS's Avatar
AcuraIntegraLS
I have a 93 EG with a B18C1 swap great motor hasn't done me wrong yet!!!! One of my friends has a 93 hatch with a H22a swap his ride is fast!! me and him haven't got a chance to race but i'm pretty sure it would b a close one and now he's turbin out the H22a!! It's all in what you want and how much you willing to spend!!! Check out this site:
http://www.hondaswap.com/forums/inde...howtopic=29825
Old Jan 25, 2005 | 05:48 PM
ummm....you'll get spanked by the H22...well atleast if its stock for stock
but i would go with the B18B...in IMO more potential...so many options *LS/Vtec, TURBO...etc...*
Old Jan 25, 2005 | 07:21 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
IMO:
B16A's were good all around engines that has a lot of potential. It is the lightest of the Bseries, and is a relatively cheap VTEC engine. These engines are usually direct bolt ins
B18B's are good for building up Frankenstein setups and turbos. They run cheaper or the same as B16A's in price and are good candidates for LS/VTEC and turbo applications. This engine is usually a direct bolt in.
B18C's are great motors if you just want torque and power all in one. Downfall is the motor is usually the second most expensive option to go with. But believe me, you will not be disappointed with the power/weight ratio with this setup in your Civic. It is open to a lot of potentials as the B16A's and is usually a direct bolt in.
B18C-R's (aka B18C5) are the king of the crop for N/A performance. The advantage of the power/weight ratio as the GSR (B18C) with the refined tuned performance of a Type R motor from the factory. This motor needs no tuning or modifications. Yet this motor is rare and the most expensive options. B16B's (Civic Type R) will be similar, but cheaper than the B18C-R. These motors are usually direct bolt in also.
H22A's are the biggest displacement engine you can put in a Civic. They usually run cheaper than the Bseries setups, BUT you do need to find motor mounts and possibly other few misc. items and modifications to make this fit in a Civic. Lots of power, also lots of weight, and more time and parts to get the motor in. Personally, I've never driven a H22 Civic before, but Im sure the power and torque is rewarding.
Old Jan 25, 2005 | 07:22 PM
honda_pilot's Avatar
honda_pilot
DeeCeeFo'
You planning on drifting with that?
Old Jan 25, 2005 | 07:28 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
I was thinking the same thing, heh.
Old Jan 26, 2005 | 11:49 AM
crazydrifter204
95DX
no im not planning on drifting
