Painting FMIC?
Old Jan 22, 2005 | 05:13 PM
dawrenn's Avatar
dawrenn
Default Painting FMIC?
My friend has a turbo LS and wants to paint his Intercooler flat black. What kind of paint will he have to use?
Old Jan 22, 2005 | 05:19 PM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
regular or radiator paint
just spray at angles and a light coat
Old Jan 22, 2005 | 06:44 PM
Kai's Avatar
Kai
Rotorphile.
A light coat of normal flat black will work fine.
Old Jan 23, 2005 | 12:07 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
I did that with an ordinary can of spray paint. Looks so stealth so no one thinks I have a turbo until they hear the BOV. I have noticed a bit of "chipping" of the paint from road debris, so maybe do two coats and then seal it.
Old Jan 23, 2005 | 06:50 AM
PDiggityDogg
the more coats you have the less effective its going to be...
Old Jan 23, 2005 | 09:49 AM
Kai's Avatar
Kai
Rotorphile.
Yes, but a single light coat won't make a difference.
Old Jan 23, 2005 | 10:21 AM
Nelson's Avatar
Nelson
Administrator
I would suggest just getting the FMIC anondized, most effective & less likely to 'chip'.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Jan 23, 2005 | 10:38 AM
Kestrel's Avatar
Kestrel
Push to shock!
I second anodizing.
Old Jan 23, 2005 | 10:40 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I third. Painting will act as an insulator which will, in turn, keep the heat in and not allow it to dissipate as well. I do not recommend painting any type of coolant device such as a FMIC.
Old Jan 23, 2005 | 09:18 PM
Jafro's Avatar
Jafro
I'm made of meat!
It's possible to annodize it yourself. There are how-to's posted somewhere on tha intarweb that I have read. I no longer have the links. It would be a cheap mr. wizard-style DIY project.
Painting an IC is teh duh.
Edit: You can buy annodizing kits, too.
http://www.caswellplating.com/kits/aluminum.htm
$300. Ouch.
