Brake Pedal
how do i get my brake pedal stiffer i got new brakes and the pedal feels the same and i kinda slow down the same is there any way to make the brake pedal a little harder to push down. thanks
disconnect the vacuum supply to the brake booster... that's really unadviseable though, cause it'll also make it harder to stop.
other than that, stainless steel lines claims to give a better pedal feel, though i've never had any personal experience with them so i can't say for sure if it'll do what you want.
Originally Posted by westcoaststyle
bleed your brakes.
h:
SS lines will help the feel because the lines won't be able to expand when you press on the brakes.
h:SS lines will help the feel because the lines won't be able to expand when you press on the brakes.
Originally Posted by shifty35
Absolutely... also, you could find a ITR master cylinder (1", should bolt right in) / booster. Do you have rear drums or disks?
