Are Integra or JDM front disk brakes the same as civic?
cx power!
Originally Posted by chimchim
I don't want to lose my ABS on my 97 EX... so is my best option for an OEM rear disk swap to go with the integra rear disks? (What years should I look for? Are there concerns with using older than my car parts?)
Originally Posted by shifty35
Daggum it people, Integra calipers have a slightly larger piston diameter than the Civic calipers. Rotor diameter is the same...
Thats what I thought... then everyone was telling me I'm wrong. I have GSR calipers sitting in my room and they don't look the same as LS calipers
f*ck...how many times do I have to say this shit before someone actually listens to me? God this board pisses me off sometimes.
It doesnt matter what year integra you get them off of...91-01 all work - but for simplicities sake 94-01 is what you want becuase of the bushing size.
As long as you relocate your sensors that are on the civic, you don't even need the integra's abs units. And before you ask: All trailing arms are IDENTICAL. Meaning that your civic parts will bolt right up, no problem.
The em1 si was not offered with abs, in the states. So if you want to keep abs you will need rear hubs (not necessarily entire rear sets) from a car that had abs equipped.
Del Sol vtecs came with that stock (I am positive about the 96-97, I only assume on the 93-95's)
But like I already said, keep it simple, if youre confused. Just look for integra rear arms and brakes. They all had abs, so there is no doubt that you can retain it. (Though, if your civic does have abs...it should already have rear disc).
OH, and for those that think that gsr front calipers are special, they only LOOK different because the ls and gs use a different style of pad retainer clip. The piston size between all integras is THE SAME. I don't care if you listen to me...I know Im right.
