Which civic is the v-tec?
Old Jan 7, 2005 | 02:32 PM
Tankard's Avatar
Tankard
Originally Posted by TTT
Uhh, heh... thats alittle off. You can get a b16 for that car for under 3k.
http://www.jdmshit.com/parts/engines/index.html
Old Jan 7, 2005 | 02:42 PM
Kestrel's Avatar
Kestrel
Push to shock!
You were looking at the entire car right? A 2000 Si will probably run you about 12-14K no matter where you look.
Or you could just swap the Si's engine into your CRX...it'll be lighter and faster h: :yes:
Old Jan 7, 2005 | 02:59 PM
Tankard's Avatar
Tankard
Originally Posted by Kestrel
You were looking at the entire car right?:
Yep.
Old Jan 7, 2005 | 09:42 PM
AcuraIntegraLS's Avatar
AcuraIntegraLS
My car is Fastest! Lol 93 Hatch GS-R DOHC VTec. K20 coming soon lol Nah but GS-R, Civic or Integra Type R, Si's are Fast! It all depends you know if the motor has work done to it!
Old Jan 8, 2005 | 04:26 AM
ED9man's Avatar
ED9man
driver
The Del Sol VTEC was another DOHC VTEC civic.
Fastest DOHC VTEC Civic was probably the CRX SiR not sold in the U.S., but it is pretty close between the CRX, EG SiRII and the EK Type-R. I could be wrong.
Old Jan 8, 2005 | 06:56 AM
Paul's Avatar
Paul
Eater of Rice
Originally Posted by Tankard
Actually, i've got a 91 CRX si. I'm sure this car would be faster than the civic if i got the b16a for it. Probably faster than the civic DOHC as it sits now. I was trying to figure out which civic has the DOHC motor, so i could search traderonline and see how much they go for. And to my surprise, they go for around 14k bucks or more, used. I did'nt plan on spending that much for a civic.
It's not, the 91 CRX Si is heavier than a 92 Civic CX or VX. The only Civics with DOHC VTEC motors in the U.S. are the Del Sol VTEC, 99-00 Civic Si, and the 02-05 Civic Si (DOHC i-VTEC). If you want a good running motor, I highly reccommend www.hmotorsonline.com You can find various B-Series motors from them. Keep in mind you have a CRX Si, which makes swaps a tad bit more difficult than the 92-00 Civics.
Old Jan 9, 2005 | 04:01 AM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
motor wise the EK Type-R with the B16B engines were the fastest due to a bit higher compression, creating 15-20hp more then the SiR B's.
Also, it was mated with a Type-R tranny , with a different final drive and gearing, which also added quite abit speed wise, im sure.
