quickie about exhaust
Old Dec 21, 2004 | 09:38 PM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
Default quickie about exhaust
im gonna be ordering my exhaust tomorrow, to install it all i have to do is take old one off and put new one in its place right?
if so how high should i raise the car to install it.
Old Dec 21, 2004 | 10:08 PM
Josh M's Avatar
Josh M
The higher the better honestly..........with jackstands........it can be difficult to get enough leverage behind tough welded in bolts.........on a lift its much easier to work with.
Old Dec 22, 2004 | 12:27 AM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
as high as you can get it really WITH JACKSTANDS.
As xsentrix said, the exhaust flanges/bolts can be a real PITA without propper leverage.. cheaterbar, whatever.
Or borrow someones lift..
Old Dec 22, 2004 | 05:06 AM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
have fun with the spring bolts.
Old Dec 22, 2004 | 06:35 AM
shifty35's Avatar
shifty35
You could go with my favorite method... buy new ones, and break all the old ones.
Old Dec 22, 2004 | 07:09 AM
Josh M's Avatar
Josh M
LOL
Yeah that method is good I think they actually recommend in the exhaust instructions that u buy new ones anyways.
Usually if you spray a little WD40 on it it won't be too difficult......
Old Dec 22, 2004 | 08:45 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
I actually just jacked up the passenger side and stuck jackstands underneath both jack points. It was a pain to get some of those bolts loose so I recommend WD-40 or the like all the bolts and hangers. Also let it soak about 10 minutes. Does make things alot easier.
Also get yourself a flex socket adapter: http://www.sears.com/sr/javasr/searc...s+%26+Ratchets
It will help to get to the cat bolts.
Autocross Help Page
Old Dec 22, 2004 | 09:27 AM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
well my uncle is a mechanic so i'll prolly just have him do it for me since he's got all the tools and a lift.
Old Dec 22, 2004 | 11:18 AM
Redcivic's Avatar
Redcivic
One of the original OG's
So why did you ask then if your uncle has a lift.
Old Dec 24, 2004 | 09:57 AM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
because i wanna see if i was able to do it at home, but ive decided to just go to his shop and save myself the trouble
