reverse light install on auto to manual conversion
Old Dec 20, 2004 | 05:17 PM
B16A2_power's Avatar
B16A2_power
PR0J3K -CIVIC duty-
Default reverse light install on auto to manual conversion
did a manuel conversion and i was wondering how to set up the reverse light and everything.,
Old Dec 31, 2005 | 04:03 PM
civictuner's Avatar
civictuner
Default Reverse lights hook up
In order for the reverse lights to work later on, the wires will have to be removed from thier location near the shifter assembly and rerouted to the reverse-light sensor on the gearbox. You also have to fool the car into thinking that it is constantly in park. Do this by removing the shift lock solenoid from the ignition, so you can remove the key from the vechile once it's turned off. I hope this answers ur question.
