Tire Pressure!!!!
Old Dec 16, 2004 | 08:45 PM
civic_96's Avatar
civic_96
Default Tire Pressure!!!!
Hey PPL!!! ! I need some help!..what is the recommended tire pressure for passenger cars? I dunno Also, Does anyone have any spoilers for a 96 Honda Civic! I need one..cheap tho!
Old Dec 16, 2004 | 09:13 PM
bambbrose's Avatar
bambbrose
check on your tires.. it'll give you a general idea of what the pressure should be.. I ride around on 35psi, lower for the track of course
Old Dec 17, 2004 | 04:47 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Which is wrong. That is the MAX pressure you can put in your tires.
Do you have a manual? Look in it and read. If not you can always search on the net. Most Civics are from 32-37.
Autocross Help Page
Old Dec 17, 2004 | 05:23 AM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
on mine i usually run 32 all around.
Old Dec 17, 2004 | 07:08 AM
According to the sticker in the driver's side doorjamb it says 30 in the front and 29 in the rear.
Old Dec 17, 2004 | 09:12 AM
bambbrose's Avatar
bambbrose
I know that the tire pressure on the tire is the max, but I was just referring to it to get a general idea.. Mine say 42max, and I run 35
Old Dec 17, 2004 | 10:59 AM
CivicSiRacer
You said this:
The MAX pressure on the tire's sidewall is not the general idea. That's the max pressure you should put in the tire which is not the same as the OEM pressure. MAX pressure on my AZENIS are 52psi. MAX pressure on my snow tires are 37psi. That's a huge spread.
Autocross Help Page
Old Dec 17, 2004 | 10:56 PM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
He will learn what max presure meens when he blows a tire... When I got my car, the guy had 50PSI in the stock tires, and the max was like 32... I almost had a heart attack!
