Wheel well
Old Dec 13, 2004 | 08:57 PM
cobbcustomz's Avatar
cobbcustomz
I used to rub in the rear wheel wells, when my car was lowered with anyone in the car. After i got my fenders rolled The problem went away.
This was on 17x7 with 205/40/17 tires 40mm offset
Old Dec 13, 2004 | 09:07 PM
as soon u lower the car also *didnt quite read all of the post sorry....* ur camber will be off no matter what...and having 17s wont help either u will need a camber kit and an alignment afterwards...
Old Dec 13, 2004 | 09:28 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Originally Posted by 93civicsedan
Thanks for that info siracer. My rims are 17x7.5 with a +40mm offset w/ H&R sports and tokico shocks. I always get rubbing up front even when I am alone in the car. Could I get spacers to correct the problem? I think Im going to just upgrade my suspension soon.
Max: How do you like the omnis? which did you get? ive been doing some reading and overall most people are happy with them. I think I may buy them soon.
Spacers will make things worse. What you need to do is get different rims with a better offset and preferably 7" wide instead of 7.5".
Autocross Help Page
Old Dec 13, 2004 | 09:30 PM
CivicSiRacer
Originally Posted by LowSky
i was told the right size was 215/45/R17 (if you switch from 185/65/R15) and 40mm offset was fine... then again i'm driving a 2001 civic not a '92
The right size for most Civics (2000 and earlier) are:
185/65x14"
195/55x15"
205/45x16"
205/40x17" (and actually it should be 215/35x17" but there is no such size)
Whoever told you doesn't know anything about cars.
For your car you would use (if you want to keep your speedo and odometer accurate):
185/65x15"
195/55x16"
205/45x17"
Autocross Help Page
