97 Civic Engine
Originally Posted by carrnut21
VTEC seems like it would be a high selling point for a car, why not put it in the valve cover, other civics have it printed on it.
Originally Posted by PDiggityDogg
What do you mean "enable vtec"?????? Its already there if its a y8... If vtec wasnt working you would get a cel (more than likely)
:doh: i should have rephrased it, i know it has vtec but how can i tell if vtec is reach or w/e .....
Originally Posted by Kai
If you're in the upper rev band and the check engine light is not on, that's how.
My check engine light is on..cant find the problem tho..car seems to run smooth:dunno: maybe its a broken sensor? I should take it to the dealer and have them scan the ECU huh?
h:
WHA>>?My check engine light is on..cant find the problem tho..car seems to run smooth maybe its a broken sensor? I should take it to the dealer and have them scan the ECU huh? Umm.... you could be messin up your motor..... If you CEL is on, then your motor will be in gimp mode... And I believe Vtec will not engage, I actualy thought it wouldnt let u rev over 4500? But thats just what I read... Dude when u got a CEL treat it as if the engine is running on no oil... and if u drive it, or run it, you will ruin it... Take it to Autozone if u drive it, and if not check it urself... Its not hard at all... And it could save the life of your motor..
