High RPMs?
Old Nov 19, 2004 | 03:25 PM
scraw56's Avatar
scraw56
Default High RPMs?
I was wondering if anyone could tell me approximately what kind of RPMs I should be getting when running at 65mph and then at 80mph. Its an 01 EX with 45,000 miles. Seems like its running higher than normal but can't really remember. Thanks for any help.
Old Nov 19, 2004 | 03:32 PM
CA VTEC Sol's Avatar
CA VTEC Sol
unless you changed your gearing, it would be exactly the same as the day the car left the dealership
Old Nov 19, 2004 | 03:36 PM
ED9man's Avatar
ED9man
driver
He is right, unless you changed gear ratios, your clutch is slipping/torque convertor is screwed up, or changed tire size drastically it isn't any different.
Old Nov 19, 2004 | 06:04 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
unless it was super severe clutch slipping , clutch slipping is out of the question.
Did you change tire size at all? Is the transmission stock?
Old Nov 19, 2004 | 08:44 PM
Running925's Avatar
Running925
Your Powder Coater
or he wouldn't be asking this if it was manual! ... turn on thinking caps.. it's most likley an automatic if he was asking this question!!!!!
Old Nov 19, 2004 | 08:51 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
Whys that?
It is all determinate on how he shifts.
Old Nov 19, 2004 | 10:44 PM
oldskoolcivic's Avatar
oldskoolcivic
get like the biggest rim size that will fit on your car. you will definately have lower RPM's on the freeway. but acceleration will suffer alot
Old Nov 27, 2004 | 06:38 PM
dohCivic's Avatar
dohCivic
Just get a tach.
Old Nov 28, 2004 | 01:08 PM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
Get a Tach, they sell small 2" tachs for 25.00 at parts stores....Also is ur car an auto or manual?
