88 Honda Civic 5spd LX SDN 1.5 To 1.6??
Old Nov 18, 2004 | 05:12 PM
retracer001's Avatar
retracer001
Default 88 Honda Civic 5spd LX SDN 1.5 To 1.6??
I Need help! Badly!
My car is a 88 Honda Civic LX 4Dr SDN (5speed) I'm trying to do a conversion from a DPFI to MPFI This is what i have bought.
I Purchased:
MPFI Dual Point 4 Injector Manifold - Civic SI Subharness to work with my factory LX Harness, Injector resistor box.
88 Honda Civic SI ECU PM6
I want to know if the swap will work - can my LX engine be converted to work from a DPFI to MPFI.
Also Is the 88 Honda Civic SI (Distributor Cap & Roter) compatible with the LX Mounting? I think the LX Distributor is TD01 and the SI is TD02U.
Someone is telling me the SI TD02U Distributor will not fit on my LX 1.5 Engine
Old Nov 18, 2004 | 05:16 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
wrong forum.
Old Nov 18, 2004 | 07:33 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
You'll get better help in the pre-'92 civic forum. A mod will probably move this thread for you. Good luck.
Old Nov 19, 2004 | 10:09 AM
Kai's Avatar
Kai
Rotorphile.
The Si distributor will bolt you your head, the LX D15B2 and the Si D16A6 use the same head casting.
