vtec vs. i-vtec; DOHC vs. SOHC
Old Nov 13, 2004 | 11:02 PM
phil_boy's Avatar
phil_boy
Default vtec vs. i-vtec; DOHC vs. SOHC
i know this is stupid but can someone kindly answer the questions below for me. i would really aprreciate it. Thanks.
1. how does a v-tec engine work, and why is it considered as a very good engine.
2. what's the difference between a vtec engine and an i-vtec engine? which is better?
3. how does a dohc engine work compared to an sohc engine. what's their "big" difference?
Old Nov 13, 2004 | 11:08 PM
Snoopy's Avatar
Snoopy
been there done that
www.howstuffworks.com is your friend
Old Nov 13, 2004 | 11:13 PM
Kestrel's Avatar
Kestrel
Push to shock!
Check hondacars.com for VTEC info.
Old Nov 13, 2004 | 11:20 PM
phil_boy's Avatar
phil_boy
thanks appreciate it. but can someone explain it to me in simplier form.
Old Nov 13, 2004 | 11:22 PM
Snoopy's Avatar
Snoopy
it doesnt get any simplier than from the above link
Old Nov 13, 2004 | 11:25 PM
Civic2Scooby's Avatar
Civic2Scooby
1. VTEC uses two seperate cam lobes to alter performance below and above a certain set rpm. It is considered a good engine, because it uses this technology to help get the best of both worlds as far as low end and high end performance.
2. I-VTEC is the next generation of VTEC. I am not really sure on I Vtec so I dont wanna blow smoke up your ass about it.
3. The big difference is that a DOHC motor has two cams where as a SOHC engine uses one cam. With a DOHC there is one cam for the intake valves, and one for the exhaust. The SOHC uses one cam to lift both the intake and exhuast valves.
Old Nov 13, 2004 | 11:31 PM
phil_boy's Avatar
phil_boy
thanks. but what are cams?
Old Nov 13, 2004 | 11:33 PM
Snoopy's Avatar
Snoopy
seriously... www.howstuffworks.com search for anything related to cars you want to know about.
Old Nov 13, 2004 | 11:39 PM
Civic2Scooby
heed the advice of the noopy :snoopy:
Old Nov 13, 2004 | 11:40 PM
phil_boy's Avatar
phil_boy
thanks, i'm now reading on to it. need to read a lot.
