Power windows working intermittently
Old Nov 13, 2004 | 10:29 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
Default Power windows working intermittently
sometimes, they'll work fine. Other times, they won't work.
when they don't work, I can get them to work by opening the door.
I checked the harness going into the main driver window controls, and its firmly in place. I did notice a little gunk, and maybe should clean it, but its still making good connection.
I looked at the wire loom that runs through the hinge area and it looked fine, but I haven't really taken appart the door yet to look over it.
Anyone else have a similar problem?
Old Nov 13, 2004 | 11:32 PM
Outxider's Avatar
Outxider
X-Motoring
try the pw relay.
Old Nov 13, 2004 | 11:57 PM
19.3secS2K's Avatar
19.3secS2K
is it just the one relay? under the hood?
Old Nov 13, 2004 | 11:59 PM
Civic2Scooby's Avatar
Civic2Scooby
if it works intermitently, then it cant be the relay.
what conditions are it usually under when they dont work?
if you have about an hour a wiring diagram and a test light then you should be able to track it down fairly easily. I have money on a loose connection at a connector, or a warn wire cover that is grounding out.
Old Nov 14, 2004 | 12:01 AM
19.3secS2K's Avatar
19.3secS2K
it was mostly limited to night, but now it seems to be more frequently occuring
Old Nov 14, 2004 | 12:03 AM
Outxider's Avatar
Outxider
X-Motoring
the relay is under the dash in the fuse panel.
Old Nov 14, 2004 | 12:07 AM
19.3secS2K's Avatar
19.3secS2K
I'm just bugged out why they will work again when the door opens.
like tonight, I would try to activate them with the door closed, and nothing. Then I'd open the door, and they'd work. But then I'd close it, and again, nothing.
Old Nov 14, 2004 | 12:08 AM
Civic2Scooby
its not the relay...if the relay was bad then they would never work, not just intermittenly. All a relay does is use low current to control high current. It uses an elecromagnet to pull a switch over to complete a circuit. If it was bad, then it would never allow the windows to work because it wouldnt be able to control the high current flow and it would remain an open circuit at all times.
Old Nov 14, 2004 | 12:09 AM
Civic2Scooby
I would bet that when you close the door, you are pinching, grounding the power wire to your switch. Have you tried using the other power window buttons that are not attached to the master switch? next time they dont work, reach over tot passanger side and see if that window works, but not the master switch
Old Nov 14, 2004 | 12:11 AM
19.3secS2K's Avatar
19.3secS2K
they don't work in parallel.
well, I'm fairly certain its wired in series... If I can't roll them down, none of the controls will work.... I noticed it did that when I took apart my doors to install my components
