Question about installing....
Im planning on buying a AEM coldair intake for my 98 civic ex. Can anyone lead me to a place that can show me with pictures a detailed installation cuz im a complete fool when it comes to this stuff. But im planning on learning
If not Any explanation is welcome.
Also would buying a Greddy evo2 exaust system be good, or should i got with a another brand?
.If not Any explanation is welcome.
one of the easiest installs you will do......take stock air hose off, 3-4 bolts holding air box on, go under car and take the 3-4 bolts holding the resonator in place and wedge it out, then put cai end up to the throttle body and tighten clamp to where its not loose, put other end through resonator hole and should have a place for the cai to bolt up to one of the stock bolt holes.....then go to bottom in fenderwell and put filter on and tighten clamp to where filter is securely on...easy as pie hope this helps
