TPS loose, how to fix.........
Old Nov 9, 2004 | 11:36 PM
Outxider's Avatar
Outxider
X-Motoring
Default TPS loose, how to fix.........
my tps is loose, and honda actually use rivets to hold it down. when its held at certain location the idle is fine, others the idle jumps up and down. since its riveted in, i cant make it any tighter? do i take the old rivets out and replace with screws?
anyone experience with this, please help me out. its temporary held in place with hondabond.
any help is appreciated. :cheers:
Old Nov 9, 2004 | 11:43 PM
Civic2Scooby's Avatar
Civic2Scooby
:thinking: wierd....my TPS is held on with two hex screws...so you can adjust it...
Old Nov 9, 2004 | 11:55 PM
Outxider's Avatar
Outxider
X-Motoring
shiet if it is, ima feel stoopid for postin this. ima go check NOW! h:
Old Nov 10, 2004 | 12:01 AM
Outxider's Avatar
Outxider
X-Motoring
omg b16LeiaEGcivic, ur my hero. the so called rivets r actually screws wit the heads cut off. i just unscrew one. looks like rivets at first cuz there was no head just a tip with white paint on it. now i can go buy some new screws to tighten it up.
thanks mang. :thumbup:
Old Nov 10, 2004 | 12:04 AM
Civic2Scooby
noooooooo problem... glad I could help.
Old Nov 10, 2004 | 12:13 AM
honura's Avatar
honura
Seni
Cool! I was gonna say JB Weld hehehehe good shit!`
Old Nov 10, 2004 | 02:19 AM
Kai's Avatar
Kai
Rotorphile.
Have a multimeter? Be sure to adjust it to .5 closed, 4.5 full open. The car will act weird, or just use more fuel, if it isn't set right.
Old Nov 11, 2004 | 09:24 AM
hybridhondahatch's Avatar
hybridhondahatch
for that added pep
JDM motors use screws while the american motors use rivets. my sugestion is to cut a slit in each rivet and use a flathead to tighten em down or you can try to find screws to fit it. one sugestion is to not take it off entirely cause they are a bitch to adjust again. they have to be set to 4.5v using a multimeter
Old Nov 11, 2004 | 10:39 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
actually none of them use rivits. they are all threaded. they do look like rivits though.
