Reinstalling Door Panel
Old Nov 5, 2004 | 07:04 PM
NWHatch's Avatar
NWHatch
i'm an idiot.. enough said
Old Nov 5, 2004 | 07:35 PM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
Yeah, youre doing it wrong.
Try doing it w/ the window down and put the front corner in first. Thats about the only "trick" there is to it.
(Pop your mirror/tweeter bezel off first)
Old Nov 5, 2004 | 08:11 PM
NWHatch's Avatar
NWHatch
I'm an idiot.. enough said
Old Nov 5, 2004 | 09:22 PM
jeterkm02's Avatar
jeterkm02
hatchbacks r my anti-drug
do the window first................... then snap all the lcisp in........hah
Old Nov 5, 2004 | 09:37 PM
PDiggityDogg
How is that possible??? 2" where?
The panel has a lip at the top. Insert the top front corner first and then work the rest of the top into the groove. Then just pop in the clips.
Old Nov 6, 2004 | 01:34 AM
mistacee's Avatar
mistacee
Zc powered ED9
If you can't figure out a door panel,maybe you shouldn't be doing work on your car yourself.
Old Nov 6, 2004 | 01:51 AM
Kai's Avatar
Kai
Rotorphile.
Step one: line up clips.
Step two: pop in clips.
Is it really that hard?
Old Nov 16, 2004 | 05:24 AM
96GreenCivic's Avatar
96GreenCivic
Sounds like you got it off, so you should be able to put it back on. Just roll down the window, that should help a lot. Don't force it though.
Good luck
Old Nov 16, 2004 | 05:29 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
one of the earlier posts was correct. roll the window all the way down, then you put the front corner in first. I wish i could post video on this cause if you tilt the panel the right way it goes in so easy.
