Happy Happy!
It's your ground!!!
Also check the voltage output of your alternator. The voltage regulator could be going bad. It needs at least a volt and a half more when your car is running than you're able to get with the car off.
..either that or you're pushing some serious wattage.
Ok this is my setup. I have 2 350watt 6x9's in the rear. JL Audio 6.5 in the front, pushing that I have a v12 500 watt Alpine. Sub is a JL Audio W7 12" puahing that I have a 1000 watt 2 chan Rockford amp (not the new cheap shit). Umm I have a 1.5 farid cap. The cap read 14.5 or so when radio is on but not uphigh. I do have a bunch of shitty ground. I have my cusin brining me some new connectors and ground cable right now. So I will be changing all the ground.
Holy crap! That's a boatload of wattage.
It's a real good idea for noise purposes if you ground everything to the same spot. I use another 1 gauge wire like I use for power to run the ground to the battery's ground strap and the same gauge wire that I use for power leads on the grounds as well with gold-plated terminal blocks.
No point in delivering tha juice if you can't ground it.
But I don't really need all that wire with just one crappy amp in my car now. I used to need it... (I had a sony XRU-220 deck, 10 disc changer, 3 amps, active crossover, 2 passive crossovers - pushing 11 speakers in a Toyota Pickup... 130db was considered loud back then. That was 1991, though.) I just keep taking my wiring kits with me when I part with the vehicle, because each time I run a 1 gauge kit it's about $160 to do it right. I wish I had better hook-ups on that stuff.
Yeah. Well my brother inlaw has a bigger setup and he has the samething I have and he has no issues what so ever. The whole car is grounded stock. The amps are grounded to the Cap and then a wire from the cap the the chassie. I had it setup a bit diffrent this morning and it helped out a bit. BUT!!!!!!! Let's say the windows are closed and the car is on and radio is off if I try to hit the window switch up while there closed I see my lights diff a slight slight bit. I don't know what the help to do. The cap say 14.8 14.9 and I think that it good. I know the ALT works because my old batt never died. Ehhh help!
in my 98 civic im running 6 1/2's sony xplodes in the doors at 120 watts a piece and 2 6x9s in the rear at 160 watts a piece 2 pioneers at 2 ohms 800 watts a piece and a directed audio 600 watt amp for the subs....lights dimmed a tiny bit before but when i threw together a ground wire kit in the engine the dimming stopped completely..that and it idles, starts, and shuts off better and a little better throttle response...grounding is the key to any electrical/stereo system...if u have a 4 gauge power from the battery to the amps and a 16 gauge ground...just isnt going to worl...ground wire should always be atleast the same size as the power wire or your going to get bad sound and power/ground ratio
