o2 Sensor
You need O2 sensors (OBD2) in order for your engine to run correctly. The ECU will think that you are leaning out because it will not read anything from the O2 sensor so it will compensate by ritchening up the air/fuel mixture causing your performance and gas mileage to decline.
What's the point of removing your O2 sensors? What's your reasoning?
I was runing without it before i swapped!
When i bought the car i did not have them (the guy that had the car took them out so he could run a straight pipe)
I really didnt care about the d16 and I drove around for around a year without o2s
and had no problem.
i dont know if im going to be as lucky with my new engine but I dont want to risk it
and had no problem.
