springs
Old Oct 27, 2004 | 09:54 AM
randomtask77's Avatar
randomtask77
Wanderer
Originally Posted by loctoday
so is it longer in the back or shorter?
The longer springs in the front, shorter in the back. Ever see a civic up on a lift (where all 4 wheels are off the ground)? You see that the front wheels drop lower than the rear wheels. To accomodate that suspension travel, the longer springs have to go in the front.
Old Oct 27, 2004 | 09:55 AM
loctoday's Avatar
loctoday
got it...that makes sense..thanks
Old Oct 27, 2004 | 10:22 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Originally Posted by randomtask77
Other way around dood. Shorter springs go in the back.
Gah, told you it's been a while. Thanks for the correction man.
Old Oct 27, 2004 | 10:29 AM
randomtask77
Wanderer
It's cool. The only reason I remember it is because I hate the fact that I have to jack up the front of the car higher than I do the back when I change wheels. h:
Old Oct 27, 2004 | 03:56 PM
Human Hybrid's Avatar
Human Hybrid
Lmao..Correction everyone! Shorter springs in the front..longer in the back!
Old Oct 27, 2004 | 03:58 PM
Hondaman's Avatar
Hondaman
Black Pearl
Actually the reason you see that is because the front suspension is built a little differently then the rear. If you set the front strut/spring combination side by side with the rear, they are almost the same length.
Old Oct 27, 2004 | 09:47 PM
loctoday's Avatar
loctoday
yea i kinda figured that...since i put the longer ones in the front and my car still looks like its slammed...but thanks for da help ...i'll prob do it tommorrow
Old Oct 28, 2004 | 02:23 AM
Kai's Avatar
Kai
Rotorphile.
WTF ever happened to the days when people bothered to buy Hayne's, Chilton's, or Factory Service Manuals? :a:
Old Oct 28, 2004 | 07:30 AM
loctoday's Avatar
loctoday
i do have haynes manual...it does not say anything about which spring goes where...thats why i asked on here
Old Oct 28, 2004 | 08:02 AM
Wharbone's Avatar
Wharbone
ok do the shorter springs go on the front ? or the back? im putting my stock ones back on..i dont know, there are two that are longer than the other two..im assuming those go in the back right?
The front's will have the coils more evenly spaced. The rears will most likely have the coils closer together at the top and more spread out at the bottom. From my experience (H&R sport) the rears are shorter.
