clutch question
Don't need a flywheel But I like to have mine changed anyways because I rather have the clutch and flywheel make new groves instead on the new clutch molding to the old flywheel. Hope you understand that.
it could also be that the slave actuator where it touches the fork needs to be greased. that fixed my issue. if its dry you will hear the metal on metal sound from time to time. just pull off that rubber boot and grease it up.
