Radiator Replacement
Old Oct 12, 2004 | 10:07 AM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
Default Radiator Replacement
Quick run through, pls correct me if im wrong....friends' 5th gen.
Cracked Radiator....To replace, drain, undo hoses, unbolt, replace, rehose, fill at top of radiator......
no tricks on these right?
Thanks, Scott
Old Oct 12, 2004 | 10:10 AM
92eg6's Avatar
92eg6
99 CG3 Owner
you pretty much got it, make sure the engine is cold, and fill the rad up to the top, place the cap on, turn on the car, go back take the cap off and fill till its full, when your car turns on the engine will pull some rad fulid into the engine. this is what i was told by a Honda Tech, when i replaced my on A SOHC. hope that helps
Old Oct 12, 2004 | 10:11 AM
lgbr's Avatar
lgbr
Wal-Mart Shopper
Check the stickies in this forum for the helms manual.
Old Oct 12, 2004 | 10:13 AM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
sweet thanks....didnt know if there were any radical differences on the 5th gen from my 6th, and i only have the 6th gen shop man.
