99 civic dx engine swap
Old Oct 8, 2004 | 08:07 PM
jake1511's Avatar
jake1511
Default 99 civic dx engine swap
wheres the best place i can get a vtec for my car?
Old Oct 8, 2004 | 08:43 PM
jake1511's Avatar
jake1511
http://www.nippon-motors.com/Performance%20Engines.htm
i found this site anyone ever buy from there?
Old Oct 8, 2004 | 08:45 PM
jake1511's Avatar
jake1511
was also wondering if i can stick taht b16a into my car
im kinda new at modding and stuff so id like as much helpful info as possible
Old Oct 8, 2004 | 09:04 PM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
VTEC is a technology not a thing that can be added on. (well it can be added, but it's not easy at all)
VTEC explained, please take a little time and read though the info on this site. It covers a lot. Be sure to use the links on the left menu also.
you can put a B16a in your car.... I'd recommend the B16A3 out of the 99-00 SI it will mount right in and with the wire harness from the SI it will work perfectly.
you can also look at the GSR (B18C1) which is close to the same price but will give you better torque for every day driving.
Also depending on which state you are in, if they do emissions testing you need to swap in an engine that is the same year or newer or they will reject you immediately.
Old Oct 8, 2004 | 10:15 PM
CivicRacr's Avatar
CivicRacr
B16A2 came from the 99-00 SI the B16A3 came from the VTEC del sol
Old Oct 9, 2004 | 07:02 AM
jake1511's Avatar
jake1511
thanks for the link, although i have already researched vtec technology it helped me further understand what i was getting into. I was wondering though whether or not that site http://www.nippon-motors.com/Performance%20Engines.htm was a reputable site and if its prices were good
Old Oct 9, 2004 | 07:04 AM
jake1511's Avatar
jake1511
and also what would be the "best for price" that would actually fit into my car without modifying much.
Old Oct 9, 2004 | 07:51 AM
teg92's Avatar
teg92
WHAT OK YEAH!
You looking to spend around $2500 for a full swap a GSR might be around $3000
Old Oct 9, 2004 | 12:27 PM
jake1511's Avatar
jake1511
what procedures would have to be done after swapping the engine and transmission for everything to run smoothly?
