94 EX Brake Conversion: Why not use parts from 94 Civic with disc?
Old Oct 6, 2004 | 12:01 PM
EJ1-B18C5R's Avatar
EJ1-B18C5R
Default 94 EX Brake Conversion: Why not use parts from 94 Civic with disc?
Hello all:
In doing my research for my upcoming rear brake conversion on my 94 Civic EX, I always see everyone using the trailer arms from Acura Integras or other Civics.
What has me scratching my head is why don't people use the trailer arms from a 1994 with Discs. I understand the ITR Cylinder, booster and all that. But isn't obvious to use the trailer arm from the same car if it exists?
Is there a certain issue I am not aware of?
Thanks for the help
Thank you for your support !
Old Oct 6, 2004 | 12:04 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
1992-95 civics with rear disc brakes are rare. It'll work...but Integra rear discs setups are easier to find.
94-01 integra and 92-95 civic parts are basically interchangable and share the same design.
Old Oct 6, 2004 | 12:14 PM
wilsel's Avatar
wilsel
^Yep. The parts are the same, so it doesn't really matter which car you get them from.
Old Oct 6, 2004 | 12:24 PM
EJ1-B18C5R's Avatar
EJ1-B18C5R
Excellent, thanks for the assist. Just wanted to make sure. While on the topic, so if I do find an EX with the discs, should I still go out of my of way to get the ITR master,booster, prop, or should I just stick with the EX's
Thanks again
Old Oct 6, 2004 | 12:43 PM
wilsel's Avatar
wilsel
Thanks again
Good question I think the prop valve will work fine, check the MC/Booster, and make sure it's a 15/16. Not a 7/8.
Old Oct 6, 2004 | 01:25 PM
asiandoood's Avatar
asiandoood
Thanks again
Im guessing the front disc brakes on an EX are 10.2? If they are, I suggest getting a 15/16 MC and a 40/40 prop valve. If your front discs are DX/LX size (9.3) a prop valve is probably the only thing you'll need IMO.
Old Oct 6, 2004 | 01:31 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
how large are the teg/si rear discs?
Old Oct 6, 2004 | 01:43 PM
asiandoood's Avatar
asiandoood
ITR front - 11.3
ITR rear - 10.3
Integra GSR/LS/RS front - 10.2
Integra GSR/LS/RS - 99-00 Civic Si rear - 9.2
92-95 Civic DX/LX front - 9.3
...to the best of my knowledge. h:
Old Oct 6, 2004 | 04:41 PM
19.3secS2K's Avatar
19.3secS2K
:thumbup:
I think a rear disc swap is in line h: if all I'd need was a few lines/cables, the rear setup, and a prop valve, that should be no problem
