97 hatch question
Old Sep 30, 2004 | 06:16 PM
honura's Avatar
honura
Seni
Default 97 hatch question
We slapped a 96 gsr into a 97 hatch. I need to know what ac bracket/mount I need to use? thanks
Old Sep 30, 2004 | 06:41 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
del sol vtec. And use your d series compressor.
Old Sep 30, 2004 | 06:57 PM
Nelson's Avatar
Nelson
Administrator
I know this issue VERY well.
Originally Posted by MaxBoosT
The A/C Compressor was from my old D15 motor, but it is unsure whether it was OEM or a dealer installed option, so it varies.
The Bracket we used was for a B16 JDM motor. It bolts on with 4 bolts. The compressor has mounting points for 3 of those. I went through 2-3 B16 brackets and they all vary depending on the year. The bracket I need is from a 1994 Del Sol Si, BUT even those brackets vary.
So the problem was a combination of either the bolts were tightened too much, the bracket wasn't fully mounted, and that the tensioner had too much pressure.
The 96-97 del sol/ 99-00 Si bracket (38930-P54-000) only bolts the 96-00 Civic compressor.
The 94-95 del sol bracket (38930-P30-000) only bolts the 92-95 civic compressor.
You CAN use the 38930-P54-000 bracket in a 92-95 civic to mount the motor, just not the Civic compressor.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Oct 2, 2004 | 04:17 AM
honura's Avatar
honura
Seni
Thanks guys! I don't care about the AC at all. Without that mount I keep ripping my Upper driverside mount to shit.
Old Oct 2, 2004 | 04:32 AM
CivicRacr's Avatar
CivicRacr
if you dont care about the a/c then just any b-series bracket will do
